using a tap m7
dsb2014
This post is 3639 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
for metric the drill size is thread size less pitch.
so for an M7 with 1.25 pitch you need a 5.75mm drill bit.
If the threads have gone you may not be able the tap out to 7mm. Have you thought of recoiling it? this would keep it 6mm.
depends where this stripped thread is I suppose.
helicoil/timeserts would do for side cases
Is the thread totally fekked. Can you not just run a 6mm tap down it to clean the existing threads
I wouldn't tap to 7mm there shouldn't be enough metal left to make a decent thread it will be weak and fail.
Yeh" helicoil kit.. gives you drill bit - tap -insert- tab breaking tool. you can get it right, without guess work,, :yeah:
http://www.ebay.co.uk/itm/RDGTOOLS-M6-X-1-HELICOIL-KIT-THREAD-REPAIR-KIT-/370774984037?pt=UK_Hand_Tools_Equipment&hash=item5653e94565
That not a bad price for a single kit.
