my DT175MX this winters mini project
Airhead
This post is 3823 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
this winters rolling restoration
Did this over the last few weeks, it wasnt tatty or owt but ya know how you just feel you have to do stuff in winter! ::)Decided to smarten up the arse end of the DT
It started with yet another take a chance buy of yet another swing arm...only difference is that when this one arrived I knew that finally...I have bought a good un with no butchery and no pitting...still in the original manufacturers paint coat after 33 years...awesome, Thanks DK ;D
after a good pressure washing with hot water
and a coat of zinc primer and gloss black...rattle cans of course 8-)
knowing this was a next move in the rolling resto...in Oct 2011 I bought from France ebay a rear inner and black outer mudguard, I bought it because the inner guard looked promising and you just dont see them like that anymore, anyway for a grand total of 30 Euros it arrived and I cleaned up the outer guard and promtly ebayed it, crikey it fetched £65 'go figure' as the Amercans would say!
so heres the inner after a good clean up with power washer and scotchbrite...gold dust
and off to the electroplaters for a freshen up
Like I say you just dont see em like this, so this is why this fella is asking £175 for one :o
http://www.ebay.co.uk/itm/dt175mx-dt-175mx-dt175-rear-mudguard-/221170983581?pt=UK_Motorcycle_Parts&hash=item337ed1629d
while I'm at it I fitted a grease nipple to the swing arm where it pivots and drilled through the pivot bush...I reason that the grease will serve the purpose of not just lubricating the bearings but will also stop the mounting bolt seizure issues too
and lastly the chain tensioner bolt gets the same treatment + re-zinc... these things are continually in motion and wear away the bore of the tensioner and the bolt
Couldnt doo all this without a quick tart up of the old 'De Carbon' gas shock could I...more aerosol therapy
I've got a NOS chainguard and pillion rests too to go on when I get around to it 8-)
;D
Show winning stuff Airhead. MInd you, the DT always looks spot on.
The drilled through the pivot bush is a great tip. People drill and tap the swingarm and then fit a grease nipple and all of the seizing is inside this bush and the swingarm bolt which gets little of no grease.
Heh i will have to use the dt for squires this year. Show you what a real dt looks like......ha ha...
Looking good paul. Hope mine doesent get any idea's.
Getting a new shop later in 2013 - it will come with the house I'm having built - and when I do I will finally be able to do this kind of work instead of letting my projects languish. My swingarm whispers to me, but I ignore it for now. Excellent thread, Paul.
Nice tip! It always seemed like it could use a little more grease distribution in there.
  • 10 months later...
Airhead I`ve just realized i`ve never seen some pics of your bike. Care to share?
