Hazard warning lights fault
nigel smith
This post is 2979 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all
The DT125X 2005 i have has hazard warning lights, I have a slight problem when switched on they flash once then nothing the indicator light on the dash stays on.
My indicators when switched on left and right work fine.
I can only find one indicator relay on the drawings.
Does anyone have any ideas ??
Also as they are fitted are they part of the M.O.T ??
Any advice would be very welcome.
cheers
nige
Are your indicators/bulbs standard? I had a similar problem when I upgraded my indicators, and the new ones exceeded the wattage of the stock relay.
I think they are standard, i think ba9 type not LED or the likes
thanks by the way
Edited by nigel smith
forgot thanks
Yes but you need to check the wattage of all the bulbs, and compare it to that of the relay.
Hi all
cheers
nige
I can assure you Nige they are not part of the MOT, only indicators are but not hazards.
  • 1 month later...
hi all
i have had a look at my rear bulbs which are aftermarket and i cant see the wattage, presuming they are over ten watts and the relay cant cope i have had a look on ebay for a different relay and found these. see link
My standard relay is FE218BH rated a 10w x 4 for the hazard lights 10w x 2 for indicators
Could i use the FE246BH rated at 21w x 4 for hazard lights 21w, 23w and 27w x 2 for indicators
http://www.ebay.co.uk/itm/281833651894?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
what i want to know is for £6 second hand will this solve my problem or cause other problems with indicator speed ect
thanks in advance
nige
That should be fine.
Funnily enough it's only the wattage that affects the speed lol
Huh. Power is a product of resistance, current and voltage. So all 3 affect the speed....
True. But a change in wattage affects the current and resistance therefore the speed.
I probably didn't word that brilliantly but hey ho
  • 2 months later...
Hi finnerz89
finally got round to trying the higher wattage relay and it works a treat so just wanted to say thanks for the advice
cheers
nige
Excellent, glad it worked!
