350LC Losing coolant
mcferreira100
This post is 3356 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Whats the coolant that edd China endorses that never boils so no pressure on gasket. Would it work in LC?
Damn..still getting a few bubbles in rad although water not rising in expansion reservoir (keeping sidecover off to keep eye on it). Also have not been for a lengthy run as yet.
This non boiling coolant sounds real interesting.If its ok to use on this bike it sounds like it could help with my problem. Will make sum enquiries this side to see if I can get it or something similar.
Here you go Mc, try this http://www.evanscoolants.co.uk/
Cuts out rust and all the other things that make water a pain in the arse, watch the video and that will explain it all.
Here's another one with an LC350 http://www.evanscoolants.co.uk/news/evans-coolants-launch-powersports-r/98
Thx Slice..spoke to a guy in SA who just started importing the engine ice coolant. He doesn`t believe it could cure my problem..he reckons something not right with that head (even though it was just skimmed). I will wager though, a good coolant will go a long way to sorting it. Not to mention better lubing of waterpump and radiator. Will check out the Evans product.
