xt 550 holding back
Beefy
This post is 3697 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I have an xt 550 1982 which is up and running but:-
when you open it up it feels like its holding back and you get a back fire off it when you ease off
had the carbs cleaned and checked
had the valves checked
some times it will run ok but the next time it is flat as shit
any idea what to do next
Cheers
Beefy
Sounds like fuel starvation , make sure theres no crud in the tank or tap.
TTB
Sure there are no air leaks carb side?
Next time she holds back , pull on the choke ,, if it responds , then shes lean.
