Gilera 4V project
drewpy
This post is 3193 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
decided to make a hot wire cutter tonight so I can carve the new seat foam.
came out really well although it took 3 different chargers to find the right amperage
nothing more to report yet as the wheels are at Manchester Xtreme :)
managed to shape the seat foam and building the bottom engine this weekend.
found this on youtube, 90cc and 168kph :eusa_shifty: (104mph)
bloody thing wheelies on power too
]http://youtu.be/TFuvrlLJDdg?t=2m11s
went to build the bottom end today and I noticed i have the wrong mains bearing :)
I also noticed the new 5 speed cluster has a blued fork selector, can I reuse this or is it best to find a better part?
blue-5th-gear-fork-selector_zpsb3a327a1.
well things have moved on a bit more;
tool the seat to Matt in Hyde to get it covered and I picked up my wheel from Manchester Xtreme
looks ace
rear view (makes the rear seem larger)
not sure whether to go for a traditional ribbed front tyre or go modern and get stickier, I'm leaning towards sticky ATM
and I also eyed up the headlamp I'm using
that's why I needed longer fork ears
still got about £500 to spend on this yet :eusa_shifty:
that's going to be a real stunner drew you've change my way of thinking here, co's the was a time not so long ago when I wouldn't look twice at a 50cc bike, and when I first seen this I thought to myself Why? but now I'm beginning to open my eyes
can't wait to see it finished now.
looking great drewpy...keep the momentum up
love the handlebar :thumb:
how was the kicker you picked up from Stafford then?
I've stripped the paint off and had to file a bit more to open the gap in order for it to grip the shaft properly.
will prob repaint it as the chrome has been ground off, sorted I think.
those handlebars are original tomaselli ones and I've kept the patina on them too :D
Just awaiting Bob Wright to find me a 5th Gear selector fork so I can finish the bottom end.
I matched up the ports yesterday to the cases and they were about 1mm out which is a lot for a two stroke. I'm leaving the ports alone as they are the 6.2hp ones
BTW those are not the rear shocks, just mock up ones
  • 3 weeks later...
YAY the seat arrived!
picked it up from Matt Caulfield and it looks great, see for yourself
259cc529-ea4b-4f8b-bd03-ee0376090a08_zps
:D
  • Like 2
Ooh that does look sharp!
came out just as I envisioned.
project stalled now as I need a 5th Gear selector, and time and money......
i take it that self-fabrication is out of the question?
I don't have the facillities but maybe I might have to get someone to make one.
bought tyres today, Heidenau thingies, German make so should be good.
fitted them tonight and the front was a bitch to fit and my fingers were knackered, the rear was dead easy and it just popped on!
Now I can weld on the front mudguard brackets and work out how to fab a tie bracket for the TLS brake.
Looks like you might have it finished before I pop my clogs. Lol.
aw Paul,
It'll be done this year , but I'm also into the FZ. wheels are at powder and got a good set of am26's cheap.
just need to sort out the seized suspension relays
