R125 Chain
Adam_Sciberras
This post is 5589 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi guys,
I have a YZF-R125
My chain is rusty : (
How did it get like this ?
How do i get rid of it ?
I do lube it with some "Shell" Lube that the dealer gave me, do i need to do this more often ?
Thanks in advance
Give it a good clean with a rag and some petrol or chain cleaner then spray with the correct lubricant.
Rain caused the rust, It happens dont worry!
Repeat after me:
"I will not use petrol to clean my chain because it will destroy the O/X rings"
Petrol will eat away at the rubber O rings (or X rings) and cause a grease leakage. This will dry out your chain and potentially cause it to snap (to put it simply without going in to great detail).
oh dear i herd it all now
definatly not a good idea.... a rag with some oil on it,padock stand and rub it to get ride of rust patches does the trick
Taken from the manual, should have done this the other day!
New to this too :blush:
Cleaning and lubricating the
drive chain
The drive chain must be cleaned and
lubricated at the intervals specified in
the periodic maintenance and lubrication
chart, otherwise it will quickly wear
out, especially when riding in dusty or
wet areas. Service the drive chain as
follows.
CAUTION:
ECA10581
The drive chain must be lubricated
after washing the motorcycle and
riding in the rain.
1. Clean the drive chain with kerosene
and a small soft brush.
CAUTION:
ECA11120
To prevent damaging the O-rings, do
not clean the drive chain with steam
cleaners, high-pressure washers or
inappropriate solvents.
2. Wipe the drive chain dry.
3. Thoroughly lubricate the drive
chain with a special O-ring chain
lubricant.
CAUTION:
ECA11110
Do not use engine oil or any other lubricants
for the drive chain, as they
may contain substances that could
damage the O-rings.
Repeat after me:
but if you don't have O/X rings.................. ;)
but work on the assumption that you do. Plus thats a few seconds worth of petrol wastted..
i have a fancy gold chain on my 600, and i use white spirt to keep it bling! works a treat :D
YOU POZER UUUUUUUUUUUUUUUUUUUUUUUUU B)
I've always used WD40 to clean and Castrol chain lube to lube, got 27000 miles out of my R1 chain with out any problem, the only reason I've changed it was due to the front sprocket not looking it's best, every two weeks I give it a quick clean, if you do it regurally it wont take long and the chain will last for a long time. :D
So just spray WD40 on it and rag it clean, then Castrol chain lube afterwards, evenly on the chain? I've yet to lube mine.. heh.
Thats the way i do it, and when cleaning you may as well make sure the chain slack is as it should be, it will help make it last longer as well.
