Yamaha Chappy LB50 No Spark
42653steve
This post is 2657 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
ohms test, or you could connect the battery to the coil and then break the connection, that normally will cause the coil to spark if things are ok
