R6 Oil Light
O-T-B
This post is 5508 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi.
I've got a little problem with my 2001 R6.
I was out riding the other day and the oil warning light came on. The bike sounded like it was a bit noisy. Almost kinda sounded like the radiator fans had kicked in or something. In particular the noise sounded like it picked up when I had the bike on lean round a left hander.
I got the bike home, checked the level and it seemed low so I went to get some oil. A couple of days later I've gone back to the bike and the level's fine.....even a little high :unsure:
The light's no longer on and I've not been out on it since <_<
Has anyone experienced anything similar or has an idea what the problem might be? :huh:
Hi.
Low oil level?
The oil warning light on the R6 is a oil level warning light, the oil should be kept to the max level mark.
No it isn't.
The warning light is a LOW OIL PRESSURE warning light.
No it isn't.
Taken from the 2001 YZF-R6 owners manual Part No 5MT-28199-E0, Section 3-2 Indicators and warning lights.
INSTRUMENT AND CONTROL FUNCTIONS
3-3
3
EAU03723*
Oil level/coolant temperature warning
light “ ”
This warning light has the following
three functions.
l When the engine oil level is low,
the warning light comes on and
symbol “ ” flashes. If this occurs,
stop the engine immediately
and add engine oil to the specified
level.
l When the coolant temperature is
too high, the warning light comes
on and symbol “ ” flashes. Stop
the motorcycle and allow it to idle
until the coolant temperature goes
down. If the temperature does not
go down, stop the engine. (See
the “Engine overheating” section
on page 6-46 for further instructions.)
and the coolant temperature is too
high, the warning light flashes and
symbols “ ” and “ ” come on.
To check that the warning light is working
properly:
l Put the transmission in neutral or
apply the clutch lever.
l Turn the engine stop switch to
“ ” and the key to “ON”.
l The warning light will come on and
symbols “ ” and “ ” will appear
in the display.
If the warning light does not come on,
have a Yamaha dealer inspect the
electrical circuit.
EC000118
CAUTION:
_
l Do not operate the motorcycle
until you know that the engine
oil level is sufficient.
l Do not operate the engine if it is
overheated.
_
NOTE: _
Even if the oil is filled to the specified
level, the warning light may flicker
when riding on a slope or during sudden
acceleration or deceleration, but
this is normal.
_
1. Oil level symbol “ ”
2. Oil level/coolant temperature
warning light “ ”
3. Coolant temperature symbol “ ”
For more Info look HERE>>>>>>>>>>>>>
Hope this helps ?????
