Jog r project
luke.russell.771
This post is 3442 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
rubber mallet and tap all round the sides and it should move.
you'll hear the difference as it lets go
Yer the best thing is to put oil in it and leave it to soak through over time might even take a few days to free it up then start knocking it with a mallet as Drew said, take care not to go mad and snapping the fins off the barrel, also heat up the barrel not the piston.
Ok luke " the best penetrating fluid is ATF-acitone mix ,,, = nail varnish remover,&Auto transmission fluid. spray that in there :yeah:
This mix will pull in. [ capillary ] spray it In [ mix up fliuid and fill an old window cleaner bottle ]
