Hi guys need some help please :)
Hitchen187
This post is 3717 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Most reed blocks are marked "UP" but on yours I dont think it matters as they are even top and bottom and the reed stops are the same T& B right? if not then the smaller stop goes to the bottom
I think this was answered in a previous post of yours
The most likely causes are; the carb is not assembled properly or you have an airleak. High revs with them slowly coming down and not idling properly are classics airleak symptoms.
Try and keep the same issues in one thread as people can read the full history and see what has been suggested and what has been eliminated.
Running a 2 stroke lean will hole the piston.
Ok so heres were im at now iv followed the advice iv been given so far which has been a great help Iv rebuilt the carb and sealed up the inlet manifold and reed valves the manifold has no holes init and looks in good condition iv also checked the crankshaft seals they seem ok and now it seems to be idleing fine but when i try to rev the bike it bogs out like its being starved of fuel is there anything else i should look for
Assuming you have done all the jobs so far correctly.
Does it bog at standstill or when trying to ride?
At what part of the rev range does it bog and does it clear at any point?
It does it with choke off and it happens if i open the throttle fast it bogs and tries to cut but if you twist throttle quickly on and off a couple times i can stop it from stalling if you get what i mean
It does clear if i let revs build slowly at a standstill just bogs if i put full revs on quickly and i havent tried to ride it yet since iv resealed all inlet manifold up tonight but it was cutting out though before i cleaned carb out after around 200 meters of riding like it ran out of petrol but kicked up again eventually also seems to run better if i have ppetrol tap on reserve
Have you tried it with the petrol cap off?
Have you cleaned out the petcock (fuel tap)?
Is it new fuel and have you cleaned out the fuel tank?
so with choke ON it's OK and choke OFF it dies with throttle...is that right?
if so, this is quite normal with a cold engine, is your engine cold?
I leave choke on 5 mins but bike eventually dies like runnin out of petrol but will start up after a few kicks with choke still on and idle the same and still bogs wen i take choke off also iv noticed oil or something going on the front pipe of the exhaust near the manifold is that a gasket problem and would this affect anything
Pilot jet is clean and the 2 adjustable screws on the carb are set to 1 and a 1/2 turns out iv been told this is yamaha factory setting but if there is a better 1 than that you no of ill happily give it a go :D
Did you take out the pilot jet " i would, thers more than 1 hole in it, your problem points to pilot jet blocked,
