1989 xj600 problems with bike help please
Jobigee1982
This post is 4095 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
dina giv up on her, start with taking off fuel pipe, [ to see the flow] if thats good . remove the plugs, they"l tell you whitch is running ritch [ black] white/ tan= lean,. renew plugs anyway,, check plug caps too , , run it ,if no better , pull the carbs for inspection :yeah:
Would like to thank everyone for there help bike has now had full service turned out to be loose wire in coil pack and had a good ride out today was very surprised how well she goes :-) any idea if you can get panniers and rack for one of these ??
you can get panniers for them, although you would probably find rocking horse sh*t with hens teeth in it with less effort/money, there are mounting points for panniers in the tail unit which are blanked off with little plastic bungs, if fancy a bit of fabrication you could make a set, likewise with the rack
