Bike only starts with high beam on???
Grouch
This post is 4113 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Recently I upgraded my bulbs and ever since the sidelight has stopped working and now my bike will only start when it is on high beam. What could be causing this?
I knew I should of just left the lights as they were and not interfered, it has caused loads of problems.
Thanks
Hey Grouch a couple of ??
1 does the bike turn over on low beam? but not start
2 If you pull in the clutch in netural will the bike turn over on low beam?
3 By side light do you mean the signals and is it just the front or front and rear? And do the signal work?
4 Can you start the bike in gear with the clutch pulled in?
I'm thinking, with your own self confessed inexperience in working on bikes, is that you have mixed up / disconnected / disturbed some wiring in the headlamp. Get a wiring diagram take the light off and have a look
