yb100 forks
alec2507
This post is 5430 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Morning all, i done the fork oil seals on my yb100 last weekend, took it out for a run yesterday and it felt hard on the front end, have i put too much fork oil in (approx 160mls) or not enough i didn't fill it right up it was about 2cm from top, regards alec
Sounds like there is too much fork oil - I know its a pain but I would remove them and empty the oil into a clean container and measure how much you have got - you should have around 320ml. If you have more just refill each leg with 160ml and you should be ok.
:D :D :D
just a quick question..
not that i need to know as for now, but how does one change fork oil??
do the seals just rip out, pour oil, and plonk a new set of seals on?
thought id ask, rather than getting a pair of long nose pliers to my forks! :lol:
