wild foamy
  1. wild foamy replied to drewpy's topic in Yamabyss
    ah screw this, im off down the pub.
  2. wild foamy replied to mailee's topic in General
    SA80, more badass than Glock only thing more deadly than an SA80 is a foamy with an SA80 and a susat
  3. wild foamy replied to iandouglas's topic in General
    ooh look at you, tools all laid out neatly on a little board, i bet you're one of those saddos that names their spanners...
  4. wild foamy replied to drewpy's topic in Yamabyss
    Not contempt with scaring Grouch off, you're now trying to get rid of me! but thankyou for comments, i have been working out more often lately...
  5. they are aftermarket alloys so definately bigger than stock, i have some plastic arches which i still need to put on and need to bond some metal braces to the inside of the fibreglass wings to bring them out in line with the rest of the body. jobs still to do: change starter motor connect gear linkage, change water pump (its leaking) new handbrake cables bleed brakes (probably need new master cylinder seals) bleed clutch make some sort of bonnet lock mechanism completely refit the interior. I also have a pair of Corbeau Forza bucket seats which came with the car when i bought it, but if i put them in i wont be able to move the seats forward to get anything in the back
  6. Reminds me of the final days of Benson before it was infested with fish heads,
  7. wild foamy replied to drewpy's topic in Yamabyss
    fucks sake drewps -.-
  8. mine is strengthened with box section braces, they came with the new subframe i bought when i converted it from an automatic to a manual. Also treated it to a lick of paint today
  9. Hey peeps, dragged my old mini up from my old base last week, it was looking a bit sorry for itself, one of its eyes was missing, various garden life living in and around it. after a few days in the workshop it is now alive! (although i have discovered that the used starter motor i bought 2 years ago is knackered), had a slight issue when the ignition coil exploded and sprayed everything with boiling hot oil, but other than that Mumbles is well on his way , i ditched those crappy sealed-beam headlights and picked up some bright shiny H4 units at a landrover sortout for £3 each, result!, the bonnet still lifts up as normal but you can also flip the whole front end forward for ease of maintanence There's another very poorly looking mini sat in the car park over here, mostly stripped out, was going to see if i could get hold of the owner and maybe use it as a trailer/barbeque kind of thing
  10. wild foamy replied to iandouglas's topic in General
    bidding is legally binding (in a nutshell, if you win it, its yours). However if you win something and circumstances change (your car fails its MOT/your trailer gets nicked) the seller may be able to cancel the transaction and a refund will be issued to both parties. likewise, my brother bid on a dodge ram van, described as "very good condition with a few rust spots", after a 300 mile trip with a trailer he found the pillars were full of filler, body was rotten, bottoms had rotten out of the doors and the engine was misfiring, so he came home another 300 miles with an empty trailer, filed a case on ebay and they refunded him the full amount including deposit
  11. hmm... could modify the old ones?... i need some thinking juice, im tapped out...
  12. wild foamy replied to mucker1983's topic in General
    Maybe because youve just enlightened someone else to the joys of motorcycles?
  13. wild foamy replied to twincle's topic in The Bar
    mine used to have "my other toy has tits" on the tagline although the DT had "one day all bikes will be this slow"
  14. Ah, the magic roundabout... one of my first rideouts was across the magic roundabout with some mates on our peds to george whites in swindon, about 8 of us all on 50s' having just passed our CBTs... it was carnage
  15. could always break it?
  16. yeah, these yokes arent going to work . need to find a set with 185mm centre-to-centre, 36mm stanchion holes and a 63mm offest. oh well, im off to B&Q to get some flat steel to mount my pilot lights to, no way they will fit inside the clocks.
  17. Nothing to worry about Andrew, just keep those oil changes regular and check the cam chain tension at regular intervals
  18. witth the battery charged and the bike running at a fast idle put a voltmeter across the terminals, should be about 13.5v -14.1v, my pre-div regulator/rectifier went pop and it was a simple case of unplug the old one, plug the new one in. when mine popped it took the main fuse out with it.
  19. Well peeps i finally got round to changing the yokes on the FUCR (cheers again , Tommy!) but they dont fit! thats the last time i trust a google search for advice..., i need a set of top yokes with 36mm stanchions, 185mm between the stanchion centres and a 63mm offset, the XS ones Tommy donated are more like 55 offset (stupid me should have checked...) . does anyone know which bike has yokes that fit the above description?, also the stem on the XZ frame is quite long, and fitting a whole different set of yokes is going to be a pain in the ass ,
  20. wild foamy replied to bippo's topic in General
    Kinda mistook the title...
  21. £122 for a pair of tyres?!, when i put new ones on Project Mong they were only about £70 the pair!
  22. Hop-up - an upgraded part Elevator - lift Fag - homosexual (not cigarette!)
  23. That's not how you do it!...
  24. Sniff, i got shown that photo in training!, a bomb trigger that didnt go off
  25. Pahahahahahahaha!...
