wild foamy
  1. Stako make 7 litre lpg tanks designed to fit inside topboxes, then all you would need is a small reducer, another standalone ECU and injector(s), i read somewhere that all scooters in shanghai are LPG as they wont allow petrol ones on the roads? (wether there is truth in that i do not know), it wouldnt be all that difficult to make one run on lpg i dont think, may be something i should consider, would be great for nipping around the base
  2. wild foamy replied to tobi evans's topic in General
    You will bow down to me!...
  3. okay, so you've removed the battery as a possibility in the equation... that really only leaves the starter motor, if you leave your bike cranking over for 5 minutes then it is likely to cook your starter motor and drain your battery, anything more than 5-10 seconds on the starter should be plenty to start a week two-stroke, if it isnt starting on the peds battery but is starting if jumped from a car it could likely be that the starter is drawing too much current for the ped battery and not leaving enough power to spark to crank over, had this problem with my XJ600 once when it had a dodgey battery on it, used to bump-start it everywhere until i got a new battery but seeing as yours is variator driven you wont be able to do this, make sure your battery is fully charged and put a voltmeter across the terminals before hitting the start button, within the first few seconds note the voltages, anything much below 9-10 suggests too high a current draw for the battery (knackered starter or shorting solenoid), not so much a problem on 12v batteries but that sort of problem on a 28v aircraft battery has enough energy to weld... keep that in mind when playing with wires
  4. this thread is like, a year old dude, that aerox is probably on the scrapheap by now, besides the Jogs were always better peds imho
  5. its probably pressed in, or you may need to have the key in the barrell to actually withdraw the pins and allow the barrell to be pushed out, i think on my XJ turbo cap i pressed it out on a bench press, machined a recess in the bottom of the barrel and put a circlip in to hold it permanently
  6. wild foamy replied to GREIGE's topic in Projects
    following this with interest, god i miss that sweet-ass XJ of mine... i got a feeling the fireblade wont do 50mpg . may have to buy it back before i leave benson... forgot to add, looks like your bike also has the Motad exhaust system, they are prone to rotting out in the collector box, kind of a crap design really, the downpipes are stainless steel but the collector box and tail section are mild steel and as i said they tend to rust away due to the moisture collecting at the lowest point in the pipe, good luck finding an original exhaust system though, you will probably find rocking horse sh*t with hens teeth in it easier than you will find a complete system for sensible money, same can be said for the pannier rack!
  7. wild foamy replied to drewpy's topic in General
    should put my 2nd ex on there... bitch took off with my CD collection and my A7X hoodie, f'kin loved that hoodie... and my CDs
  8. incredible well done tbh... sounds like the kind of thing i would do
  9. from what i remember, my DT50 had a stock main jet of 98, with the big bore kit on and a bigone exhaust and expansion pipe i jetted it to about 110 and moved the needle up one position. check the colour of your spark plugs, this should be a rough indication of mixture, struggling to start could be an indication of lean running
  10. Yeah, That's my name on the back, you can either have the shirt with nothing on the back or for a little bit extra you can have text on the back (in this case, its my name and a funny little slogan). PM me with what you want and i can get it all arranged for you and give you a final price
  11. wild foamy replied to Paulwhite's topic in General
    A burning yamaha building could work... This is food for thought Shirts will be on the way shortly, just sorting it all out with Alex
  12. wild foamy replied to Paulwhite's topic in General
    Get hubby involved? maybe you guys could do a "Hunky fireman carrying a strikingly beautifull damsel from a 'burning' cardboard building" scenario... like this: By Foamy, age 19 and a half :3
  13. wild foamy replied to Paulwhite's topic in General
    well who knows, maybe we could do a page together, you with your heart stopping good looks and me with my... erm, personality i suppose...
  14. wild foamy replied to Paulwhite's topic in General
    wasn't thinking of the bikes... tbh... :/
  15. wild foamy replied to Noise's topic in Yamabyss
    is it an XS?...
  16. I heard he was taking viagra to stop himself rolling out of bed...
  17. wild foamy replied to Paulwhite's topic in General
    seriously peeps... YOC calender shoot?...
  18. carbonised plugs = rich mixture, if you are in doubt about your ignition timing it may be best to refer to your haynes for correct timing
  19. Yes, I remember this job well... Every year my trusty old rattler would need new fork seals... From what I recall they didn't need a special tool as such, strip the front end down and remove the forks from the triple trees, then remove the bolt from the bottom of the stanchions with an Allen key, can't remember what size but it was probably 6 or 8 mm, the old seals are held under a circling, a good set of pliers is all that's required to remove these, with the caliper removed a sharp upward pull should seperate the legs from the stanchion, reinstallation is the same in reverse, i used 10w oil although 15w would be better as it request front end dive under braking, from memory I think it's about 400ml although without a Haynes manual it is only a guess
  20. wild foamy replied to Paulwhite's topic in General
    This has given me an idea... How about a YOC calendar shoot?... although due to the lack of females it would most likely be 12 pages of Sacha... Not that I'm complaining I'm en route back to hometree now peeps, you will be pleased to know that I have exiled the demons from my laptop and foamynet is operational once again , will update this thread later after I have adjusted the designs
  21. likewise, boobs were good,
  22. wild foamy replied to Paulwhite's topic in General
    Back from London for a week so can now get some shirts ordered, drewpys shirt will cost an extra 1.99 with a name on the back, you can have as much writing as you can fit on it for the same price so you can add a slogan or quote Alex, do you want one in white and one in black? Can't really get the same shirt with black and white on it... Youd look french
  23. the only thing that stops me contemplating suicide is drooling over all the hot women who come through to the olympics... i even get to rumage around in their bags... found some weird and wonderfull things including but not limited to live chickens, strange looking vibrators, lubricant (not the 10w40 kind...), handcuffs, ballgags e.t.c
  24. wild foamy replied to Paulwhite's topic in General
    So far i have: Drewps - Large plain back black - £12.35 shipped to Drewps address Airhead - Large plain back white - £10.35 shipped to Airhead address Alex, couldn't find what size you wanted in the previous pages, also the above listed shirts are all plain-backed, no names or slogans on the back, not sure how many other mods are after a shirt, wont be ordering these this week as im just about to catch the love train back to faaaackin' london, will probably be back in a few days though so will check this thread again before ordering and will let you know the total, but as a rough
  25. wild foamy replied to Noise's topic in Yamabyss
    One less noble warrior enjoy it while it lasts
