idle at 5000rpm
Rufus17
This post is 392 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
You either have a massive leak in the inlet system, or more likely the slide or butterfly in the carb is stuck open
or cable sticking. if idle hangs, def too weak, if bogs too rich
