Tracer 900 Clutch cable routing
mr_robd_lon
This post is 1144 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi Folks,
After the 12k miles service my Tracer 900 came back with a loose chain and finger tight rear axle nut! Some months later I noticed that the clutch cable was getting trapped between the lower triple clamp and the frame.
I bodged it with Gorilla Tape and I'm now at the 24k miles service and doing it myself this time so I want to correct the issue but I don't know what the proper routing should be?
I've looked through the service manual and the Haynes manual but either missed it or its not in there. The Haynes manual shows the cable guide near the radiator but not what happens higher up from there...
If someone could share a photo of theirs that would be amazing.3b77487159d79554201a298ef23be294.jpg2edabf7f975c6c942caa71a797140274.gif
Sent from my SM-G960F using Tapatalk
It should go in front of the top yoke
https://images.app.goo.gl/wA4NauCEqafr5f4CA
Lifted from the tracer forum...see what I done there
I'm assuming it also goes in front of the lower yoke, since that's the one it's being trapped by...
Yip
Over the front of the two yokes, then follows the natural route to the outer clutch housing
You need to keep it as smooth as possible to reduce bends, and therefore drag on the cable
