My 1968 YR2C restoration project.
Fast Eddie
This post is 2154 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
After successfully restoring a 1964 Yamaha YDS3, a 1972 Kawasaki H1B, a 1964 Honda CB77 my next project is a 1968 Yamaha YR2C.
I have rebuilt the engine and Hydra blasted it and it looks better than new. This bike only has 10,000 miles on the speedo so mechanically was sound and in good condition. It doesn’t even need to go over size just a new set of std rings and a hone to bring it up.
I am after an air filter as one is missing and I cannot find one anywhere, I would take 2 as the one I have really needs replacing so if any one could help I would be very appreciative.
FDD72_D4_B-0_DDE-4534-9284-979_AECE8_FE4
Starting to dismantle
E52834_E8-_F529-40_AB-_BFD5-9_C13_C71_A9
Images of motor after Hydra Blasting and assembly.
C91_B802_D-8161-4_CEB-_BDDA-1962_CA766_D
221381_C9-_F5_F5-4_FE8-84_D5-54940_F364_
Edited by Fast Eddie
I don't use apple so not sure if you can get
https://postimages.org
You have to register, but it's no big deal
Once you upload a picture click on the share button, then copy the hotlinks for forums url. Paste that in your post then remove the 's' in each of the https codes and away you go
wHAT hosting site you using,,,,,, imgur  is the bollocks, ,,,,pissbucket is the pits,,
