Please help, Yamaha XS1100 newb
don007
This post is 2402 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello, my 79 XS1100 has been running fine up until last night. This is 4th actual time riding it, I've rode previously from getting from the shop weeks ago but now put some issues on myself.
local shop everything that was fixed/replaced.
* fuel line replaced
* dirt bags used dot 4 brake fluid, but haven't encountered a problem...yet . I even gave them the manual.
*carb washers were replaced (and carbs were actually rebuilt when bought it from the owner.)
*gasket float chamber
*rebuild kit for rear brake.
*60/55W halgon h4 ( recently did)
Yesterday I pulled the choke out for a few seconds and even rode with it out. Reason being because I had recently started turning my petcocks to OFF thought it needed some fuel to go through. I honestly don't if I should turn petcocks OFF after when not parked and not in us? But I obviously set them back ON, this is the time where I encountered a problem. I was accelerating fine and slowing down fine up until a few minutes later I could not accelerate my bike even if tried shifting, I stopped in a parking lot to let choke out in let the bike sit neutral. I haven't rode my bike for 2 days that's actually when I started setting the petcocks OFF because I read that you should get in the habit of doing it so nothing clogs. As I was letting it run in the parking it sounded like it warming up maybe or that everything was feeding right at a steady 2 rpm on neutral. let it sit for 5 minutes then took it out down the street. Everything seemed to run and shift fine but again I encountered the accelerating problem it's almost like a dull sound from the exhaust not what it would normally sound like. Stopped in another parking did the same thing again let the choke out then took it back home. Also I noticed when I left to choke out and revved it a little and let off the throttle the rpm was high that's when i pushed the choke back in (while stationary in neutral). Another thing I did was fill the fuel tank to brim almost, I read that's a no no. When I finally turned off my bike I heard pressurized hissing sound coming from cap, I opened then shut it. The sound went away. Too much pressure/air in fuel tank perhaps at the time? I feel like problems started occurring when I messed with the petcocks for the first time.I will add an audio file soon.
I apologize for the lengthy paragraph.
Thanks.
Hi
first off the xs1100 petcocks do not have an off position  they have on-res-pri .. the pri position allows fuel to flood tho  where as on & res only supply fuel when a vac is formed via the engine being started .. you should only use the PRI position on the petcocks to 'prime' the carbs with fuel after work on either the carbs and/or motor. However with the age of XS1100 you may have knackered the diaphrams within the petcocks.
The Dull sound from the exhaust sounds like the fuel lines have been routed wrong .. have you removed the carbs and/or the fuel tank recently ?
You may not be able to see with this picture but my petcocks have
Are indicated in this order from left to right
R  ON  OFF
And I have not removed the exhausts or fuel tank. Like I mentioned before it all started when I decided to set them on the off position.
My 79  xs1100 had vacuum carbs so no on/off. Maybe the US Model was different, or maybe some previous owner changed them.
Anyway reading your post when you stated that "Another thing I did was fill the fuel tank to brim almost, I read that's a no no. When I finally turned off my bike I heard pressurized hissing sound coming from cap, I opened then shut it. The sound went away" tells me that tank breather is blocked. You will need to clean out the breather hole in the cap
Try running the bike again and when it starts to bog down open and close the petrol cap and see if that clears it.
  • Thanks 1
R  ON  OFF
Those petcocks are not as Yamaha intended ... which may indicate some issues .. looking at them they look like Kawasaki petcocks which are not vac controled .. I guess the 2 vac take offs on the inlet manifolds have been blanked off so no undue air is being allowed into the inlet tracts ?  I would doubt that Yamaha would have given the UK vac petcocks and the US manual ones from my time at the factory they would use as many common parts across as possible through models for different markets ... I would guess your after market petcocks are just not allowing the volume of fuel through to allow the engine to run
Fuel shut off valves, aren't the same thing as petcocks. The thing was I thought having them OFF is what I was suppose to do when parked but apparently that wasn't a good idea? Jimmy I let it run with cap open for a few minutes, it sounds normal like it did when I had got it. I thought putting in an extra gallon wouldn't really matter but I suppose it does.
1 hour ago, don007 said:
Fuel shut off valves, aren't the same thing as petcocks. The thing was I thought having them OFF is what I was suppose to do when parked but apparently that wasn't a good idea? Jimmy I light it run with cap open for a few minutes, it sounds normal like it did when I had got it. I thought putting in an extra gallon wouldn't really matter but I suppose it does.
Don
What I meant was let the bike run with the fuel cap on until the bike starts to bog down, then release the cap whilst the engine is running. This will indicate whether the vent in the cap is blocked. I would ride round the block a few times as it's not a good idea to run an air cooled engine in the stationary position
Them pod filters are gash too,   i bet it takes ages to warm up.[ cough & splutters]..  usually runs lean also, ,  that hissing sounds like a  vacume .[cap breather blocked,,]
However with the correct vacuum Fuel shut off valves,
 as you can see from the image the petcock is totally different to the one in your image without these there is a chance you may have to do some mods to get around your problems
