Tank
Alan.Tdm
This post is 2730 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Over the years I have used probably most types of tank cleaning advice and the very best and cheapest was, string together with some wire a bunch of old nuts, the bigger the better, and pour in a 50-50 mix of white vinegar and water and rattle it round till its clean. Makes your arms ache and you look a right twit from behind  (I'm told by SWMBO!) then use heat to dry  it as quick as you can then use a sealer of your choice, just make sure it's ethanol proof.
Sorry should have added flush with distilled water once it's clean to counter the vinegar.
