1974 yamaha DT 250
Roy Theiner
This post is 3052 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Clutch drag? Gearbox issue maybe
What exactly do you mean by misses/breaks?
Hi roy "   the DT250 was POiNTS  up to 1980,.  is it after market system ?    I think  it would be carb more than CDI,,   as there reliable,
Sounds like a DT250 A , have you checked behind the magneto , 250 and 360 have a tendency of rusting due to condensation.
Its also well worth checking the carb and making sure the jets are clean and the floats are the correct way round and the levels are correct.
TTB
