neutral problem
jennings1992
This post is 5210 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
just a little problem thats getting anoyying, my bike doesnt like going from first to neutral when its running and not moving, its fine but a little stiff when im rolling and its also ok when the engine isnt running.is this normal or do i have a problem here because i wouldnt think its normal, thanks for any help. forgot to mention, if you get it up to second when its running and not moving it goes in ok from second
obviously adjust the clutch as that may be dragging
also try adjusting the final drive chain, as that helps too!
