Airhead
  1. Greetings Nigel, better late than never, I only wasted 13 years Hey we're neighbours
  2. I assume there will be an electric cable and sensor attached to the wheel hub, is there...is damaged? Thats about all I can suggest
  3. Greetings, nice little trail iron
  4. Airhead replied to MXCT272's topic in Classics
    Please dont double post the same problems, it works better to have all your answers in one place and it's easier for anyone willing to help to follow the progress, i'm locking this one
  5. Hey mate did you know we have a new members forum where you can post an introduction ...that would be great Try squirting a little gas down the sparkplug hole, this sometimes works but you didnt say whether the plug is getting wet?
  6. a few points here The rings are different, the top one has a 'keystone' profile section (it's thinner on the inside circumference than the outside circumference...this on goes into the top groove The other ring is flat in Its profile section, this one goes into the bottom groove but first put in the little springy thing so that the ends are either side of the locating peg You'll notice that the rings have a shape ground into the ends so that they fit correctly around the locating pegs
  7. Greetings nedadrian, like your choices fella how about ?
  8. It's a 1979 DT50F Larry
  9. Airhead replied to GREIGE's topic in Projects
    well given there's no batterys in it I'd say you're on the right track, a simple continuity check with a multimeter would confirm it
  10. Greetings Jimi, there will no doubt be a fuse near to the battery, you might check that and the holder?
  11. Airhead replied to GREIGE's topic in Projects
    it's not an emergency light is it, those ones light up when power is removed...well they do until the battery runs out!
  12. you sure it's not the flasher relay that's buzzing?
  13. yeah get it adjusted right and check the nipple at the engine is seated properly
  14. Maybe the clutch isnt engaging, you should have around 10mm free play at the end of the lever
  15. did you check the front sprocket is secure?
  16. Airhead replied to drewpy's topic in General
  17. Greetings Mark, nice intro
  18. Airhead replied to jimmy's topic in General
    Only ever used rattle cans mate, most of the prep will be common sense...rubbing down...de greasing...masking...priming etc etc
  19. yes..use what you have
  20. To check the seal on the magneto side Start the engine and get it idling about 2000rpm using the throttle stop adjutment screw. Can of WD40 with a straw attached, direct a sray jet through the slots on the magneto rotor aiming towards where the seal will be. Listen for any change at all in the way the engine is running or change in idle speed. Any change of course indicates a bad seal A nice easy check
  21. could be, do you know how to do a quick n easy test of that?
  22. yes we get the picture mate
  23. see what you mean mate, those clocks are dreadful !
