1981 XT 250 overcharging
Ryno2203
This post is 1101 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi
I have a 1981 yamaha xt 250 with electrical problems.
Its a 6V system with seperate voltage regulator and rectifier as far as i understand. I have changed the regulator and cdi box with second hand parts but problem still persists.
At the moment we are still getting 40V AC at the battery. Does someone know what i can look at or change?
Yeah... 40V doesn't sound right at all!
I have no idea how to fix the problem or even what the problem is, but you could always try to suck up some of that power by slapping a load of xenon headlamps on the front like a 1970s Mod Lambretta..! 🛵:eusa_dance:
Other than that, I'm sure someone else will have a better idea! :D
Hi there,
The purpose of the regulator is to 'regulate' or reduce the voltage!
The generator produces the AC voltage, and if you were to measure directly off the coils, on the charging circuit (with nothing else connected) you will indeed find a rising AC voltage depending on the revs... the faster the revs the higher the output. On a DT 175 MX you will see 26v at 6000revs.
The REGULATOR 'clips' this voltage back down to 6 volt (on a 6v bike and down to 12v on a 12v bike) and it is this reduced voltage which charges the battery. Otherwise the battery will get fried on the unregulated  output of the generator.
So if you're getting 40v it strongly suggests the regulator is not doing its job.
You might want to have a read of one of my popular posts on a conversion of my DT175 from 6 v to 12v. It's a long read but I do detail how all the parts work, which might help you understand it. I do note also that some XT owners have indeed used my post to convert theirs. However, i must point out my usual disclaimer: this is what I did with my DT175MX not any other bike.
Moreover, I'd also like to add that 10 years later...my 12v conversion is still working perfectly fine.
hope this helps.
