SR 125 intermittent starting problems
Juddie
This post is 6492 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
SR125 intermittent (Electric) starting problems.
Sometimes it starts fine, then the next minute it wont start and wont even bump. Which means I cant go very far, cos I am scared of it conking out on me.
Given contacts etc.... and good clean and spray.
Any ideas, cos its driving me mental and I need the bike to practise ready for my test, which is real soon.
is it just electric starting on the button or kick/bump starting?
If its generaly a bad starter, have you checked the ususal suspects?
spark plug
fuel - blocked fuel delivery. do you have an inline fuel filter, i always use one as after 1300 miles i can see rust flecks from the petol pump tankscaught in the filter!
charged battery?
does the bike smoke when it does start, as this could mean worn valve guides thus letting oil seep into the cyl head causing spark plug to foul.
Ok it seems sorted for now.........fingers crossed.
The ?? clutch switch had a bad connection and got a new spark plug and its seems ok now......touchwood. :blink:
Good hope it works well now
Did know of one that used to cut out for no known reason.
turned out to be a half broken wire hidden away in the loom around the stering head
merv
