Xj6 tuning help required
andrewhall
This post is 1847 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Whats the mileage? I think that'll be fuel injected, not carbs. Easy enough to do if youve got the equipment. Always start with the simple stuff first though, plugs/filters etc, make sure the chain tension is correct and lubricated, if the fuel is more than a couple of months old, dump it and put fresh in
