2010 YZ450F clutch adjustment
BradZ
This post is 3501 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hey guys, brand new to this site as ive just purchased my second Yamaha today. As the title states shes a '10 yz450f. My question is, occasionally when in gear the bike wants to creep foward even while the clutch is in. Ive tried adjusting it at the lever but haven't been able to fix it.
Where else should I be looking for thr cause of this issue? Thanks.
The cable can also be adjusted at the clutch cover.remove the tension at the bar set the cable up first so minimal slack is in the cable then use the bar adjustment
