Yamaha DT125RE Flasher Relay
GoProKid
This post is 3772 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all, I have just purchased a 2006 Yamaha DT125RE. Its in good condition but the hazard light switch on the left hand side of the bike doesn't work properly and causes the indicators to stop flashing immediately when you switch the hazard button. The indicators do work but I'm sure that the relay is crook. Help?
Have the indicators been swapped for aftermarket ones? If so you may need an uprated flasher relay.
I had this problem when I changed my indicators from 10w bulbs to 21w bulbs, the original relay is only capable of switching 40w in total. Hence your indicators work as normal but not as hazards.
The relay from an r6 will plug straight in
