checking oil on an xvs 125
beemer328
This post is 3978 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Ok so it all sounds so simple, just look in the little window, except Yamaha have decided to put a bloody exhaust pipe in front of it, other than removing said exhaust pipe how do you check the level, I have tried moving about under it but I still cant see. Any Ideas please?
If you are doing an oil change and are unable to see the oil level through the window,
you should measure the oil as you put it in just use a measuring jug.
You just need to find out the amount of oil your bike needs.
thanks for the replies chaps, the torch tip worked a treat, all topped up and ready to go. Cheers, Gary
