Aerox Help Please !
chubz
This post is 4579 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
well basically my aerox started yesterday and it wouldnt really move, just revved... but now it wont even start and when it does it just cuts out when ever you touch the throttle..
can anyone help me please im really lost and i need to get it running, not sure if thats enough info, but thats all that happens, jus cuts out...
na mate, just trying to get a semi decent moped on the go.. looks the part after i got a handlebar conversion and few other bits.. it just wont start now, iv cleaned everything and to no avail. really stuck now :\
sounds like you got some debris in the carb causing a partial blockage.
did it rev ok when it wouldn't move?
did you change anything since?
maybe the drive belt has snapped!
iv had the carb off mate, cleaned the jets and whatnot.. cleaned it all.
yes, it did rev quite good when it wouldnt move, but more pull of the throttle it started to move slightly then it would start and the cut out as soon as u touch the throttle...
and i havt changed anything since, just had it all off and gave it all a clean.. and i also checked the belt, and its still ok, on there as it should etc...
some one said it might be the bottom end oil seal ?, is that bad, or could that just be a load of pony lol
