I'm new here and with a new project FZR 1000 (nearly complete)
henryz
This post is 5337 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hey everyone, I'm new here and I have my first Yamaha. I bought an FZR on the cheap in bits. It had almost everything with it I wanted on a custom bike. I can tell you now I am having some annoying but maybe not serious problems.
First of all I had to re bleed the front brakes, that is sorted. The wiring loom wasnt earthed properly, horn didn't work, speedo wasnt wired up (electronic), headlight was still in the box, swingarm hadn't been fitted, radiator needed fitting and needed MOT.
If you look at the pics you will see it is all going fairly well. The swingarms on, the lights are on, rad and all that jazz. I have a question though, are the 88 Genesis models supposed to have a fan with the radiator? Because I didn't get one. I can't find my thermostat switch either. MOT is done.
I was balancing the carbs today, this was taking a while on a really hot day and I noticed something hot on my leg, water was flying out of the overflow, I'm guessing this is because it is too hot and also maybe it is because I don't have a fan?
So far the bike has been driving me crazy!
Piccys:
Welcome!
Nice bike. Liking the single sided swing arm - whats it off originally? Was it hard to fit?
Hey thanks, it is from a Triumph 1050 I believe with the 190 back tyre and the seat unit and subframe is from a 916. Most of the prep work was done when I bought it, but it was a bit of a fiddle getting alignment right.
Piccys:
Hi there i have just got my fzr 1000 exup do you know if i can fit fzr 1000 ru exup forks to my 1990 fzr 1000 exup
I haven't ever seen an exup before so i'm not sure. I am trying to find out if the exup engine will fit the genesis with little or no mods.
Piccys:
That looks fantastic!!!
Any chance of some bigger pics please?
Still really impressed by that swingarm transplant! :thumb:
I can take some for you when it comes back from the garage. The mechanics seem to have messed something up. It has a custom wiring loom the previous owner made. To be honest, it's a bit of a mess and it does need re wiring or just tidying with new connectors. However, they managed to pull something out and now they cant get any power.
They spent ages trying to fix that instead of cleaning my carbs and getting it to run richer. Hoping they won't charge me for the wiring problems as it worked when I left it there.
hi just wandering if you found out weather the exup engine will fit the genesis frame.
  • 1 month later...
