DT175 Fork oil
paul65
This post is 5497 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi
I have a 1984 Dt175 which i re-oil the forks with 254cc of 10w oil but when i went for a ride it was bottoming out .
Do i have the wright oil and CC?. or should i use a heavy oil
Thanks if you can help
Hi Paul, where did you get the figure 254cc from, Its 146cc +-2 of 10w / 15w/ 20w...depending on weight of rider
Sounds like they are locking out then?
Thanks for the reply. a yamaha service center gave it to me and he told me if i put a heavy oil in like 15w it could blow the seals.
thanks
thanks
Then use another service centre cos thats bollox, If you put enough force into the forks to blow seals in good nick on good chrome you will prob knacker the fr wheel.
Hi what is Hydraulic lock???
The figure OG has quoted will be allowing for an 'air gap' which will allow room for the oil to move. As when the forks compress the chrome section moves inside the lower part of the leg. Like when you get in the bath. If you filled it to the very top then got in it would go every where.
Well the thing with the forks is they are a sealed system so the spare oil cannot escape like the water in your bath and so the forks will stop moving when the oil runs out of room. Hence the air gap. In theory if you fill the forks fully compressed you would be somewhere near but thats hardly accurate.
thanks for the reply
do i need to compress the forks when i refill the forks and do you know how much of a air gap i should have in the top of the fork?
Get a helper, remove the drain screw at the bottom of each fork, do one side at a time, hold a container against the hole and SLOWLY compress the fork, do this until it is empty, then do the other side. BEWARE the oil can squirt out at a fair old whack so hold the container correctly and dont pump too hard.
Then measure the correct amount of the oil and put it back in the top having first replaced the drain plugs
The key is, to be sure they are empty before filling them, dont worry about air gaps.
what weight oil should i use i'm 85kg?? and i'll try 146cc and i will be riding on the dirt if that make any diffidence
thanks
thanks
you might as well re use the oil 10w that you drained, after all it is new oil, unless it looks cruddy, then if thats too soft try again with 15w and so on.
