blackhat250
  1. Aye Rat " try clicking the bbr button [ that square switch top left,] you"l get a faded page, but just paste on it, . that AS1 , is a 1971, its a tubed frame. I see yours is pressed ,
  2. When the right bulb I staying on, are the indicators lit but not flashing ?
  3. Sounds a bit slow,,,, how heavy are you spur "
  4. Any update "
  5. This is a friends recently restored AS1 , is this close to your model,,
  6. Unscrew it, you"l need a small/ medium flat screwdriver, andlook at it thru a magnifying glass, see what size, ie 40/45/50, etc,,
  7. Probably a small oil leak , dripping onto exhausts, ,
  8. The pilot jet need looked at, as when screwing the air-screw in it should stumble and die. and when screwing out - it should rev up, this is why it will only run on choke,
  9. blackhat250 replied to MANNY 67's topic in General
    Hi, if you don't know what your doing ,take it to a friend who does, or youl knacker it big time,, its a 2 stroke aint it,? check oil tank also,
  10. THat looks the dogs " never sell it, tidy examples are rare,,
  11. C string,,,,,,,,,,,,,,,,,,
  12. blackhat250 replied to sunsprie's topic in General
    Well done sprie "
  13. Good start stevie " is that the local scrapyard your in ---------------------------------
  14. Hi twinpower" not very many XS650 owners in here, they were a fine bike, yams copy of the British Twin, Hope there a few owners pop up,
  15. blackhat250 replied to meatloaf's topic in The Bar
    Aye meaty, 300mls ismy threshold too,,,,,,,,,,,,,,,although" I did Paris to Scotch corner in 11hrs one day, on the old H2 kwaker, Just googled it, 502mls . ,I left Soissons @ 9am got to S,corner @8pm, was cold, still had 280 miles to home, So took a travel inn. here she was , fully load,
  16. Yip " amazing 97 with 6000mls, real bargain,,, I like the style of the xvs. Heres another about oil " A guy in USA. Rode 120,000 mls on his XT1200 Tenere , and used Diesel engine oil for most of them miles, I"l post the link when I find it,
  17. Hi biker /b, another gel to the ranks, ask questions in workshop,,
  18. Its coming along tho calpy" ...bear metal looks good, not much tin worm,,,
  19. Happened up here few years ago. killed hersell only. I think it was deliberate tho,,,
  20. I"v only one classic now, the expensive ones are sold, so may just get a normal policy, as DT is not valuable, do bikeshure give breakdown cover, ?
  21. That's some neat work IKE,
  22. You"ve double posted nomad "
  23. Hi Marc " lots of Xvs fans in here, search there posts on bling- exhausts etc,
  24. Smell the oil for fuel , sounds like your float valves are passing, I know its meant to come out the overflow, but I"v seen fuel go right thru to cylnders,
