blackhat250
  1. Yeh crank will be corroded too, as ports are open , condensation will do the damage,,
  2. Yeh " convert that to £- GB , looks ok,,,
  3. Ok mike,,, the soarse coil, provides current for the spark,,,,do a continuity test on all wires from stator,, As for the dash lights, they might be blown,,, A multi meter is a must,,,
  4. Welcome mike,,," another DT fan ,,,
  5. Bugger, the poor Gilera ,,,
  6. Why" I thot you"d had enuff humble pie ,after City were humped last week,,,
  7. Welcome,, another DT fan,,,,, input always welcome,,,
  8. Hi bb" try a new plug,,, if thers fuel ,it must be poor spark,,, Air screw is correct, what do you mean by " pilot jet in bowl is bottomed out,"
  9. blackhat250 replied to Cynic's topic in The Bar
    Did the same on friday night,,,it was glorious , , found a uninhabited castle ,, will go back with Camera next time,,,,
  10. Hi ndso" am over there in august, Manx Gp...... looking forward to it,,,
  11. Remember to use petrol resistent laquer , or they"l run on the first fuel spill...
  12. Get a compression test, i bet that rear cylinder has a burnt valve, [ popping and banging] its been running lean, [carb needs settup] this would give poor starting,,
  13. The video ,2 . Husqvarna 610 [ crazy stuff] , These guys aint gonna see pension age ...
  14. Good on yeh phill" plinngas is the founder of the XJ owners club , pop over ,,, like minded folks
  15. 60 for the bus pass Andre" Go get the buckfast in jimmbo.... You westcoasters luv it,,,,
  16. Hi rumpli , get involved in the topics,,,,
  17. Bloody ell newman " you get hours before it sets,,, more if thers polythene below it. i"v seen us go back next day, and throw buckets of water on it , and it will turn up again , then polish it,, did you have a power float,,,
  18. I know the owner of the yellow Special,,, james from Wakefield,,,
  19. Go for it coxy" bargain at that price,,
  20. Not so good felix" your on a learning curve eh " Glad your ok,, wheres that link of the Off..
  21. Drain old oil, and put in fresh amount, to the manuals spec, most Yams have capacity on case,,
  22. Frame number / engine number, too.
  23. Then the polis cottoned on you were all theiving bastewarts,,, ...
  24. It will be bite the pillow if foamy gets his way,,,
