How do I upgrade to twin disc on xs400?
Ajdoyle77
This post is 5823 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I have an '83 xs 400 seca (with the monoshock rear). I am doing a cafe style mod job. I'd like to upgrade to twin discs in the front. What do I need for forks? Caliper?
I'm not familiar with Yamaha, don't know anything about the interchangability.
Also, are there any decent upgrades for the rear monoshock?
Front twin discs, XS500/ 650 bits should do it, unless you can find a front end from newer bike that goes straight into your triple trees, as for rear shock again take a look around measure the shock and see if a later bike one fits I:e xj600 possibly
merv
merv
sorry Merv, the dohc (12E)has nothing in common with the 2a2 xs400 except the name.
for the dohc you need the brake parts from an xj550.
it is explained here in german so you will need a translator, or just look at the pictures :)
http://yamaha-xs400.de.vu/
click Fahrwerk
Thanks for the link.
I couldn't find translation for some key words. Here's what I got:
1. Fork of the Yamaha XJ550
2. Rotor of the XS 400 12E (identical care!)
3. Bremmszange one from the left side of the XJ550. (Identical care!)
4. a longer Hohlschraube to the distributor.
5. Handbremmszylinder de XJ550.
My guess is:
Bremmszange = caliper?
Hohlschraube = brake line?
Handbremmszylinder = master cylinder?
Can anyone confirm?
Drewps
Dont know bog all about modern XS,s so i stand corrected anfd thanks for doing that my specialist subject RD 250/350/400 aircooled before 1981
A good way of translating parts is go to german ebay enter the name of the part you are tryingto translate in the search box and hey presto you should have a picture
merv
ebay de
Bremmszange = caliper? yes
Hohlschraube = brake line? No quite literally hole bolt, but banjo bolt too us, to take 2 lines you will need another line of course
Handbremmszylinder = master cylinder? yes
Thanks.
Now, I bought forks from an '82 xj550 off ebay. They won't work.
the 550 forks have an offset axle hole, where the 400 has a centered hole.
Anybody out there need a pair of xj550 forks?
Thanks.
did you try to fit them anyway?
why don't you email the site owner, they usually do speak english and is worth a try. ask for the model he used!!
You're only supposed to use the caliper side of the 550 forks, so it wouldn't line up.
I may email him, or I may give up on that mod all together...
I would email him, don't give up cos when youv'e done it you get a lot of satisfaction and you learn as you go.
don't forget to keep us posted
I have an XJ550 front fork setup (w/19" wheel) on my 1982 XS400S, it works great. Bike came that way though, so I actually don't know a ton about the mod. It took a while to figure out what the front end came off from lol.
Thanks.
Sounds like those forks came off an XJ550 MAXIM...rather than the SECA :unsure:
I rode this for 13 years & know 'em pretty well.....
Put around 40k on the clock on this 1 before I traded it in on my 3rd 550 :blink:
I'd love to have the 400 back now.......Great bike......FYI....EBC pads & a steel-braided line can make a World of difference with that front brake ya know? ;)
