BEAR66 Posted November 6, 2007 Share Posted November 6, 2007 HAS ANYONE RE REGISTERD A BIKE, AS IVE GOT HOLD OF A XS 400 ITS OLD AND IS ALL IVE GOT IS THE FRAME AND ENGINE NUMBERS, CAN I FIND THE AGE AND GET AN AGE RELATED PLATE, HELP Link to comment Share on other sites More sharing options...
andywolf79 Posted November 6, 2007 Share Posted November 6, 2007 You can do an hpi check and fill in the engine number and frame number and omit the reg and it should hopefully come back with the age and status of the bike and possibly the reg it used to have. Some hpi checks require the reg to do the search but there are a few that will use basic information but you might have to go through a few to find the ones that do. Alternatively if you write to the dvla they are pretty helpfull and will be able to help depending on how busy they are. Good luck. Link to comment Share on other sites More sharing options...
fosdyke Posted November 10, 2007 Share Posted November 10, 2007 I had this years ago with a 76 RS100 - never did get the reg! But on the bright side the DVLA have a form for getting the reg using the engine and frame numbers - don't know if they charge these days though. - Otherwise you have the re-register at your local office - they will give you an age related mark based on a points system - so if your frame and engine numbers match then you get so many points etc etc. Be prepared for it to cost around £70 though - and you usually have to take the bike there! Good luck Link to comment Share on other sites More sharing options...
