DT125 Deristriction
JonRisby
This post is 2691 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
  • Replies 61
  • Admin
Yep get a new exhaust, have a bike gear thingy so you can manually open the powervalve, (or fix tzr elecrric one), add some carbon reeds and bigger jets and away you go :shock:
  • Admin
hehehe you know the things on mountain bikes that pull the cable :oops:
that sounds ok for a full system. when you have the exhaust off look up the exhaust port and you'll see the power valve. turn it through about 180 degrees till the valve is flush with the top of the port. this will give full power. don't worry much about 'performance reeds' they're not worth it in my opinion. i've tried a few out. you'll need to upjet the mains for the exhaust. usually about two sizes for an exhaust and more for an airfilter. hope this helps. any more info needed then just ask mate :wink:
right buddy follow these simple steps and your biike will be a beast change the exhaust dep is chrome and looks the beezkbeez although dtr125s pre 1999 wasnt restricted through the exhaust so ur front pipe should be alright the deps have a good performance enhancer then get the carb rejetted to a 240 they are 210 when standard then a set of boyussen racing reeds and obviously open the power valve
and all dtrs from 91 til 98 were derestricted through i think it was the cdi the black box in the rubber mount under the fuel tank change that for one off a pre 91 and ul be sorted the pre 91 although looks different still works with all the stator coils and so on obviously mine being a g reg i dont need to upgarde my cdi unit let us know how u get on
oh yes and for some better sound and very slight improvement on accelleration get a k&n filter
john what colour is your bike and did u buy it from bristol my mate just sold a black s reg to a guy in cirencester for £1200 i think the one he sold had the old style power valve on it because the servo packed on the electric one
Its blue and white. i bought it from a old kiddy in cirencester :D:) :!: . 1 previous owner and i know the previous owner hes my mums best friends dad. Your close on the price £1100 down from £1200.... :D not bad really.. that covered the cost for sum new tires. :wink: p.s the bike has only done 10K and the engine is as smooth as a babys arse :lol: and i know the bike hasnt been ramped! :P
  • Admin
Yeah forgot about that mozzy, your right my dtr was 91on a h, and had the old cdi unit, as the newer ones dont rev as high, i think that was the difference :roll:
  • Admin
Well if your good with electronics this site tells you how to modify the cdi
http://translate.google.com/translate?hl=e...DUTF-8%26sa%3DG
CLick on the tuning on the left and Schaltplan CDI on the top, for the instructions. They also show you how to unrestrict etc..
GOod site, but the site has been translated via google so is quite funny but all seems pretty simple to follow 8)
Just been out for a ride... great weather for it!:D the bike maxes out at 65MPH, 8000RPM she will cruise happily at 55-58MPH. if i change the exhuast i think i will only reach 70-72MPH coz of the gearing and it redlines at 10500 also it will only rev to 8000RPM is this normal???
Thanks
:)J
  • Admin
Thats the cdi which is restricting the rpm, the old ones can go to around 12k, check the link and it has a wiring diagram of how to change it, or get an older cdi.
just give mine a thrashing today alex i got that dep front pipe for £135 in the end from ard racing components in walsall i have details if anyone needs em
it is a very noticable difference to my old fresco{big one} i pulled away same as i usually would and the power valve seems to come in alot sooner and it was on the back wheel i was crapping myself but tried to control cause there was loads of people around
it seems to have sacrificed a little bit of top end for a lot more bottom end
which is fine for me
a.r.d racing sell the complete dep system for £175 + p+p which is bloody reasonable
