tyre pressure
Guest Tomg
This post is 6288 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Just a word of advice. I have to change my tyres due to my neglect of checking the tyre pressure. :o it has created a flat squared of spot on the front tyre. not good obviously. so i just thought i would let you know. as i had no idea a) it was under pressure (no queens lyrics please!) or B) it would have that amount of effect. but maybe im just a bit of a thicky dumb shit!!! :rolleyes:
other than that just had the beast serviced and apart from new rear pads and the need ffor new tyres everythign else is ship shape. :D
You have to check your pressures all the time Tom....besides uneven tyre wear your life is on the line if you don't.
36/42 is generally the best combination for most bikes. And don't forget to check, adjust, and lube your chain regularly too.
  • 3 weeks later...
:D :D :D :D :D :D :D :D nailed ma theory man just a walk in the park, just got to get the
last part asap :D :D
