Yamaha v50 mate 1980
Chalkey1988
This post is 2303 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi I'm new to the site and I'm  looking for any help deristricting my v50 mate 1980 model
im currently in the process off using a dremel to file away the exhaust port which is particularly blocked on the later models any more help would be very appreciated
regards
Your de restricting a 1980 townmate.
Surely thats worth more working as yamaha intended.
Well apart from filing away the exhaust port, changing the carb, inlet manifold, reed valve and exhaust system  you will have to change the primary gear & clutch as the ratios were changed to ensure the max design speed could not be exceeded ... TBF I agree with Cynic
