whos the best person for tzr125
jonnytzrroberts
This post is 3400 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hey not so sloppy. Its only the bolt you have issue with.
The bolt pulls the 2 halves together. With it broken you should be able to remove it at least. If its a dud you lose nothing getting aggressive with it using the serious tools.
I see no reason your old pv wont fit.
2strokes can be really cruel to own. They give big but you have to pay the piper.
What do you mean? The full clutch. If so most likely yes with the appropriate primary gear,oil pump/taco drive.
If you mean the clutch pack. Depends on number of plates, thickness etc.
If you want to change the basket you will need the primary gear too. Possibly the other gears as well for the oil pump and taco.
Whats up with the old one.
