Grips
HarleyJay
This post is 3548 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Get them as a pair, as the right one will be different in order to fit over the throttle slider.
Standard Drag grips comprise the rubber grips, inner chrome-plastic collars and outer chrome-plastic end caps.
IIRC, the bars will probably be 22mm diameter (but do check first), so get grips that match the bars.
