dt 125 r too high
cathunter
This post is 3974 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi my girlfriend has got a dt 125 r what she loves to ride but its a bit too high for her. when she rides she on tip toes .would it make it any lower if i adjusted the preload on the monoshock if not is there any way to drop it by about an inch any help would be goog cheers
you can buy a lowering kit for it , looks like this, mwhKsH89J7jgdDfmV2P1IJg_zps001aa7ab.jpg I think the longer it is the lower the bike sits and the shorter the higher the bike sits and its fitted just below the swing arm
Hey just rember to lower the front as well,, the same height as the rear or you will change the steering angle.And it will handle like crap.
silde the forks up and then find the right links to lower the rear the same
If I remember rightly, the DT125X forks are shorter than the standard DT125R ones.
