Dt125x USD forks
smoush
This post is 4135 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Has anybody fitted USD's to a dt? I have seen it done and need any info ie which ones will fit and how easy is it if I wanted to put ones of a YZ...
Ano it's not an good post but would be grateful for any info
Cheers
Chris
in theory you could put YZ forks (including brakes and wheels) on it providing they have the same yoke diameter, failing that you could swap out the whole 3-tree (yokes) fro, the YZ provided that the internal spindle is of the same diameter.
Would be a pain the arse if you needed to have the stem pressed in. It may also mess up the handling of the bike as they will most likely be a different length stanchion.
If its just for looks i personally wouldnt bother.
