Xt660z tenere2010
This post is 708 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Is this a ride out request or a general question about your bike? if its the latter then this should be in the work shop section or in the Bar.
  • 10 years later...
@Noise; Surely you can answer him? The poor guy wanted info... Yes, I too have an Xt660z 2010 and have fitted a power commander (with O2 sensor) also DNA air filter. It definitely makes a difference but it would be fine without. It is best noticed when in lower rev range but you might feel a little more inclined to use the throttle more and increase petrol use accordingly!
Maybe get it set up properly on a dyno, I am considering doing that. (£200+) - you need a Windows PC to set it up, dont forget...
Thread is a decade old. op only checked in twice.
  • Cynic locked this topic
This topic is now closed to further replies.
