Yamaha dt 50 Mx - No spark
steve.1995
This post is 4444 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
So i recently brought a Yamaha dt50 Mx. It was in a bit of a state so i took everything apart and resprayed everything and had to get the swing arm welded. After putting it back together i have found that the bike has no spark. The bike is the cdi version which has no points. I have checked all the wiring and everything is in its correct place. I have also brought a new ignition coil and spark plug and still nothing.
Has anyone had any similar problems or any info that may be able to help me?
Thanks
if you have another bike you can connect it up and see if it sparks then? thats the only way i can think of, have you checked all the wires? checked a diffrent plug? ht cap?
