Engine Swap 80 XS400SG to 82 XS400SJ
63-Coupe
This post is 4800 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Can anyone tell me if an engine swap from an 80 XS400SG to an 82 XS400SJ is a straight forward bolt in or are there any mechanical or electrical modifications required? Any tips or tricks?
Norm
so long as they are both sohc and have the electronic ignition, i can't forsee any problems.
it should be just a straight swap.
just have a looksey at the front mountings and see if they are the same. the engines got rubber mounted at the front about 1980
