God Awful Noise...
bobbernation
This post is 4810 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Okay,
I looked for a topic with an answer before posting this thread...couldn't find one.
So when i turn the key to engage the starter on my 81 xs400, sometimes the motor turns over fine.
But sometimes there is a god awful sound coming from the cases area. Kinda sounds like the chain is being slung all over the inside(just a description). Then when I stop and try again, the motor turns over fine. Does this sound like a problem with the starter, starter clutch, or something else I'm missing?
Bobb
Okay,
Bobb
usually the starter clutch, first check the starter motor is securly fastened.
replacing the starter clutch is a PITA
