rxs throttle cable
BRIANM
This post is 5136 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
HI ALL,
I went to check the oil pump today and found that the marks dont line up due to the cable being too tight,after this got me thinking i checked all the adjusters(the one for the carb,the one that goes into the oil pump and the one at the throttle)and i found they are all set at the absolute minimum with no way to adjust them,the cables are all tight so i assume its not the proper throttle cable for the bike,anyone know the best place to pick up one for a 96 plate rx-s 100?cheers.
HI ALL,
Hi Brian
Tis Here ;)
...Paul
