Battery Cover panel
mits007
This post is 5322 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi there,
My battery cover panel is looking a bit worse for wear (looks like the exhaust heat is getting to it - bubbles in paintwork)
There appears to be some sponge on the inside of the panel which is making it protrude more than what I would say is usual....
Is this sponge OEM or has it been placed by some ruff bugger in the past?!?!..
Any1 else have this problem?..
regards,
-Mits-
Errr..... I don't recall there being any sponge inside my panel.
If it's dead square and dead straight, it's likely OEM. If not..... I see no reason not to rip it off.
So long as the panel re-attaches snugly.
I can't recall - Do you have custom pipes? That could be yer problem......
